i dunno if this helps....but no one else has said anything, so its better than nothing, lol. but if you can follow what i mean - the ss foggies are the same size as the "flute" part in a stock bumper....they basically just replace that area. so assuming you've got a stock front bar you could just check out that and get an idea.
best to try your local wreckers, you're gonna need to look at an SS or Calais front bar and i think you will also need the mounting brackets and associated wiring as well as the lights themselves
thanks guys i havent had the chance to get a set of bezzles so i can measure up the hole. around my area holden dont stock em, n have to order them in but they want payment first before they get them in.. n the holden that stocks em are bout an hour away.. i was hoping to go for some aftermarket lights as holden want $130 each!! it should be $130 for the pair.. my question was a quick thing before i've had the chance to purchase anything and measure up. i have the wiring at the headlights, and i think the plugs there behind the dash.. the mounting brackets i'll have to have a look at how they bolt up, when i remove my front bar n try n fit the bezzels i'll grab the bezzels this week n go from there thanks
hey mate when i first got my car i spent alot on her fixing little dents and bumps and i also decided to put in fog lights. i found that the loom for the lights wast by the headlight switch and so another one had to be purchased. it is better to see if you can already find a SS or Calais bar but i payed i think from memory $130 for my SS bar unpainted. if u need anymore help just ask and i'll see if i can help you out
