justinx
- May 12, 2019
- 1
- 0
- 1
- Age
- 55
- Location
- newcastle
- ve calais
Hi people,appologies if this has been done before but i couldn't find anything.
Got an ABS/stability control warning light on for a month now, when it first came on called NRMA to check it out,old matey scanned it and said its coming from front drivers side so in my wisdom(and slackness i guess) i thought id change the sensor out myself,
Not as straight forward as i thought when i had a look it looks like the sensor is one piece with the hub,
Anyone else had issues with this? is it possible to change or even clean out the sensor without swapping the whole hub out? could it be a warped rotor or thin pads maybe causing the fault?
Thanks in advance everyone, hoping its a simpler solution than it looks.
