Front end clunking noises.
SV6WGN
42
New Zealand
SV6 SPORTWAGON
Really???? I'm also aware of the "dounut" rubber at the top of the strut failing... You can usually tell its toast just by looking at it... will be turning upwards like someones done the nut up to tight...
jfarrugia98
Penrith
09 VE SV6 - 08 VE SV6
Yeah i just had a look, one of them has a slight crack but i don’t see how that could be causing the noise. It could be the strut bearings as there is a bit of rotation a can make on them. I tried tightening up the nuts on top of the struts, but i don’t exactly feel comfortable removing the struts completely, I guess i’ll just have to deal with it or wait until it gets worse and then take it to a mechanic.
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
Is there a rubber insulator between the base of the spring and the strut plate?
jfarrugia98
Penrith
I don’t think i’d be able to tell there isn’t much room to slip my finger in or get a good view of it, maybe tomorrow i will try stick my phone camera up there to check for any damage
VTS5
TechJunkie
Sth.East\Melb
VE OMEGA 3.6L Dual Fuel
Check your front lower control arm and radius arm ball joints.
RiCeY
Australia
Turn the wheel full lock you can see the insulator if it has them.
greenacc
Searching for the billion
VE Berlina
Will any thin sheet of rubber do the same thing? Mine doesn't have the insulators, makes a few clunks over rough surfaces.
RiCeY
Australia
I would think so, its just a rubber disc.
