Hi guys i have this spinning noise coming from the front left side that sounds like a shot bearing. I have replace my front hubs and bearings, hopefully i will be changing some pulleys this weekend as well. Just wondering what else i should check? It seems to only make the noise when in drive and is worse when accelerating. Also the noise seems to be louder with higher revs. Any suggestions would be much appreciated. Cheers
Make a diagram of how your serpentine belt goes on, remove it, spin all pulleys by hand feel or listen for any thing obviously loose or has play, next step you have to be careful start engine without serpentine belt BUT only run for a 10 seconds. If all pulleys seem fine and the noise is still there when you crank it it's probably fairly serious if not youre up for a pulley, A/C compressor, water pump, alternator maybe harmonic balancer
