front left wheen issue
simoj
adelaide
VTII Berlina
hi guys,
i seem to have some play from left to right in my front left wheel. my front right seems okay. i have recently had all the bushes replace in the front z bars but it hasnt fixed it. i checked all the wheel nuts aswell and none of them are loose. what could my issue be? any help would be great.
Cheers Simo
Jonno
Vic,
what wheels are they?
might not be sitting on the hub properly
try swapping one of the wheels and see if that one is loose too,
then u could work out if its the wheel or the car
simoj
adelaide
VTII Berlina
they are just the stock wheels its a VTII berlina sedan. ill take the wheel off n swap it 4 c if that fixes it. cheers
pjdm1980
Shut up Jr I'm thinkin!
Geelong, Victoria
E1 GTS BUILD NO# 007, GQ Patrol.
Is it up and down as well it might be a stuffed hub bearing?
Jack it up and try to move it up and down.
som
thorneside qld
vt executive
perhaps it's simply a tie rod end???slide under the front of the car and get a friend to grab hold of the wheel itself and try to turn it from side to side .you should be able to see where the movement is.good luck
VTS5
TechJunkie
Sth.East\Melb
VE OMEGA 3.6L Dual Fuel
Just make sure they'r not " directional " tyres.They tend to do it if they fitted incorrectly..
