Vin999
also if you have stuck/frozen BJ TRE's Mix a solution of acetone n auto trans fluid and spray on nuts and thread and leave overnight to dilute the rust in thread, works better then any wd40
That tyre is now on the back if you read on down..
You must have to many right turns on your road.
Been thinking it might be pointless spending coin for someone to tell me i have a body issue. Because the cost of sorting such a problem I could buy a whole new car cheaper. I think I need to go back to My Car and have a chat and get some advice on what I can do that won't cost a mint.Your readings are in
What did you do to your VR/VS today? post #1122
You need to take car to a proper front end/suspension place to check out your car properly, especially as you said before it had a front end hit/damage, I wouldn't worry about w/alignment till you sort the chassis front end part issues.
Clutching at straws because you have no idea what the problem might be....Can't you find any solutions through your usual google searches?
Let us know what your car says..I think I need to go back to My Car and have a chat and get some advice on what I can do that won't cost a mint.
