Just been back to My Car and he said everything is ok and its normal wear. While the wear is not bad it is still wearing more than the other side front. He reckons there aren't worn components coming into play. I need to find a suspension place to know for sure.
That doesn't sound right, normal not bad wear and no worn components and yet you have wear only on 1 side .. somethiing smells fishy....
Reading your other posts you mentioned you got new bushes for the front of car ... did you replace the top strut bushes and caster rod bushes ?? ... you said the car had a knock on the front, you replaced 1 TRE, you have another TRE to replace and then you mention the mechanic 1 minute said you need to change worn components and then later you said the wheel alignment is all good and had a safety check and mechanic said all good, plus you traveled to sa and back, swapped the front worn edge tyre to the rear and now you have the same side wearing the edge out and want suggestions and now mycar says all is good ?????
Also have you considered... you changed rear springs/shocks and you said that the fronts need it done considering you drive a lot on bad winding dirt forest roads.
Call me wrong but most places when they do an alignment check the caster n camber components to see if ok so they can do the alignment ?????? Also it seems you spend a lot of money on twice yearly useless wheel alignments and your tyre is wearing, and qualified mechanics at different places say nothing wrong, I wonder what doesn't sound right here.
If it was me I would not spend money $500 on a useless shift kit if you KNOW the car needs important repairs.
