Front rotors stuck
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Dayvo, Aug 26, 2007.
  1. Dayvo
    Dayvo Because i can
    South East,Victoria
    VE SV6 Series 2
    i need to replace my front pads and rotors and have been trying for about an hour to get the old rotors off .There is a bit of rust around the hub where the rotor sits I sprayed them with CRC and let them sit for a while .Then gave them a bit of a tap but they won't move . Is there some sort of puller you can buy or something ¿ Does anyone have any suggestions
    Cheers Dayvo
  2. DND
    DND Banned
    Your putting new rotters on get a Bigger Hammer!! :yeah:
    Try hitting here :thumbsup:
  3. TheForgotten
    TheForgotten only human......
    quarantine
    VR EXEC
    block of wood on inside of rotor and smack the crap outta it. turn every so often to avoid the rotor binding on one side. caution: they hurt when you hit yourself in the goolies.....
  4. Dayvo
    Dayvo Because i can
    South East,Victoria
    VE SV6 Series 2
    LOL thanks mate . I'll dig out my ol' cricket gear . think i still have the nut protector
  5. goldencommodore
    goldencommodore New Member
    gold coast
    VT Acclaim Commodore
    hey im thinking of changing my rotors cause i think there warped and i want to buy some of the slotted and drilled rotor from repco. there on sale at the moment for slotted prices, r there a good buy?
  6. RockyVX
    RockyVX New Member
    VX Executive Wgn, VP Sedan, V6 Ride on Lawnmower
    Remember not to go too stupid, or you may cause a little bit of damage to the wheel bearings, with a bigger hammer anyway :)
    I know I would ! :)
  7. totq
    totq New Member
    Forest Lake Brisbane
    VR Calais 3.8, Raptor S/C
    The cross drill looks good, but for braking purpose, just get the slotted ones. Cross drilling holes means there is less surface area (or contact area) on the rotor in contact with the pads.
  8. TheForgotten
    quarantine
    VR EXEC
    ^^^ plus they have higher risk of cracking due to heat
  9. Fr3ak+--
    Fr3ak+-- Closed On Monday
    Kingswood, Nsw
    Vt Exec 5 Speed
    i work at repco dude
    aslong as you get the DBA slotted rotors and not the ****ty silverline ones you will be sweet
  10. DND
    DND Banned
    how did you go get them off ?? :D
  11. Dayvo
    Dayvo Because i can
    South East,Victoria
    VE SV6 Series 2
    I haven't got them off yet . It will be a Sunday job when the wife is at work, you know peace and quiet . I just had a look at the attachment in your previous post , Do you hit the disc from behind where the arrows are or hit it from on top ?
  12. Shounak
    Shounak The Kicking Horse
    VX Executive S2 + XF Panel Van Project
    Definitely from behind. You'll have to reach in and give it a few good whacks.
    I'd feel uncomfortable using anything other than a rubber mallet. But if you're chucking the old ones away, you can afford to hit it a bit harder, just don't go too nuts.
    Go nuts with the WD40 the day before and make sure there's nothing securing the rotors at all.
    edit: Easier with the fronts because you don't have the handbrake shoes there.
  13. DND
    DND Banned
    I hit them on the top, I not know how you can get behind isn't there a cover on the back ?
    hit and rotate
    If not you migth need some heat on it
  14. TheForgotten
    quarantine
    VR EXEC
    yeah there's a dust plate, but there's a gap when you pull off the caliper
