Hey just wondering what size spanner to get the nuts off on the rod that connects to the shocks is that 16 mm ? for both bolts?
You also need to use a spanner on the flat of the link pin (Holden calls it a spacer stud) to hold it steady while your remove and replace the nuts. Can be 12mm or 14mm.
