Front Strut Bolts
Phil257
VT 5.0 Calais
Howdy,
Do any of you guys know the size of the bolts holding the front struts. There are a pair at the bottom of the strut and need to be replaced if the strut is pulled.
Planning on replacing the bearings at the top of the strut on the weekend and need to pick some replacement bolts up.
Hopefully this stops the squeeling noises.
Cheers,
Phil
kart_racer
Races karts
VT Acclaim 5M
Not sure on that one...why not just call up spare parts at your nearest dealer?
You may not even need to remove them to get the top bushes/bearings out and in. There was a tutorial on how to do this on the Australian LS1 and Holden Forums I believe.
SweetWagon
booosted
35
Springwood NSW
VS Berlina Wagon Supercharged
Howdy,
Cheers,
Phil
From memory its a 19mm bolt with a 22mm or 24mm nut
Phil257
VT 5.0 Calais
Cheers for that, I'll try and do it without removing the lower bolts if it looks easier.
jas98
34
maryborough QLD
vs commodore V6 S2 and a BA XR6T
they say to replace them but i never did and i took them off heapos of times due to faulty struts/bearings etc.....and now i have to again cause of a brand new strut that is faulty and causeing killer knocking noises lol
