Front strut mounts worn
MarkJB
55
Ady
VE SS Commodore
hi new to the forum, I have a 2006 VE SS, I’m in SA. Just serviced the SS at Holden and the report said my front strut mounts are worn.
My question is, do Holden use the urethane bushing or the rubber?
I prefer rubber myself.
Thanks
Mark
55ams
brissy
ve sv6 sedan manual
GET ONTO SUPERPRO, BEST STUFF EVER!!
lmoengnr
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
+1 for Superpro.
If you don't like urethane, they make an OEM replacement using polylast.
Feels like rubber, but more durable than factory.
lowandslow
NSW
V2 III Monaro
Got Polyelast in the daily wagon. Can't tell the difference between it and rubber.
MarkJB
55
Ady
VE SS Commodore
Thanks for the replies
Fu Manchu
Septic Tank Pump Operator
WA.
Slug powered VZ, Cross 8 VZ, VE Calais & ya mum.
Have superpro on mine.
lmoengnr
Sunbury Vic.
What do you think about them versus OEM?
I have the polylast in the Redline, locates the top of the struts much more firmly than the OEM rubber junk, but doesn't increase the NVH in the cabin.
I have the urethane versions in the Maloo, NVH increased slightly, but improved the steering 'precision'.
When the Magnums are up for replacement, the urethanes will be fitted.
Fu Manchu
WA.
I think the OEM product is well suited for re-using in the manufacture of tennis balls, tyres, squash balls, condoms and Toyota Yaris engine mounts; if you are to compare them with the Super Pro product.
wetwork65
A wet business
VF SSV Wagon & VF SV6 Wagon
Wouldn't want my condoms to split like the oem mounts.
Then again, the thought of reused rubber in my rubbers is a bit unpleasant.
