Front sway bar link pins?
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by dans_vz, Nov 3, 2012.
  1. dans_vz
    dans_vz Active Member
    Swan Hill
    MY16 VFII SSV Redline Manual & 05 VZ Calais daily
    Hey guys,
    Are the front sway bar link pins (I think thats what they are called), need bushes in them as it doesn't look like the ones in my VZ have them.
    They just have what looks like sort of a ball joint at the top and bottom bits.
    Also are they difficult to replace them?
    And how do I tell if they need replacing?
    Thanks in advance everyone.
  2. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    Ball joint is the upgraded version and should last the life of the vehicle.
  3. glenn l
    glenn l New Member
    ve sv6
    vn-vx series1 had bushes top and bottom, vx series2-vy had bushes top and ball joint bottom and vz had ball joint top and bottom.
  4. Surfwagon
    Surfwagon Well-Known Member
    Sydney/NSW
    AMG Mercedes C63 Wagon
    1.They just have what looks like sort of a ball joint at the top and bottom bits.
    Yes correct VZ have ball joints both ends
    2.Also are they difficult to replace them?
    No, very easy with both wheels on ramps and car at normal height, hard with suspension hanging when car on stands.
    3.And how do I tell if they need replacing?
    They will most likely be broken/snapped but usually last way longer than the old bushes type link pins.
  5. dans_vz
    Swan Hill
    Thanks for the replies guys, much appreciated
