front sway bar mounting
clubsport_replica
Perth, NOR
1998 vt clubsport replica
hey guys quick question
on my vq caprice i noticed today while fitting the inner wheel are gaurd that it had all new nolathane bushes aswell as a larger aftermarket swaybar.
but i think it is fitted incorrectly, are the ment to bolt to the lower control arm or to the strut tower???
i will post up a pic of what i mean if its not clear..
cheers
Bill
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
After market sway bars sometimes bolt to the control arm. I'm pretty sure the VQ mounted to the control arm anyway, only the later models mounted onto the strut.
clubsport_replica
Perth, NOR
oh ok just that it has the mounting section on the strut asewll so wasnt sure where it should go..
thanks
ScoHar
Jizz in my pants
CHCH, NZ
VS Senator
Factory they went on the strut, there is a small conversion (slightly shorter link pins) for it to attach to the lower arm, So you have found your 3rd unpaid for mod stoked
clubsport_replica
Perth, NOR
yeh gotta start winning sometime hey...
so what is the point of this conversion stiffer cornering etc??
