front wheel making clicking noise?
speed__demond
slammed and cammed
vic
forums.justcommodores.com.au
vs statesman 5L
gfs tk barina.. im no good with front wheel drive setups so here it goes.
it makes a click noise, quite loud from the drivers side.
obviously gets faster as you speed up and ive tried swapping wheels so not that.
I tried searching it but it seems as if everyones just guessing and naming parts.
me mate recons driveshaft but I don't wanna replact it and its not nessisary
_R_J_K_
Zenki S14
Good place to start would to see if the CV boots are split open. If they are, it's pretty much diagnosis confirmed.
CONROD
SOMEWHERE in the land of OZ
VZ SS THUNDER 6.0l 6 Sp
Definitely CV joints have had the dick. Good way to check is full lock, try doing a few figure eights and they will click their heads off. The balls within them get a flat spot
speed__demond
slammed and cammed
vic
vs statesman 5L
finally got time to have a look.
def clicking nea drivers cv joint.
my mechanic mate recons it could be in the diff tho because u can get a bit of awobble on the inside where it slots into the diff.
he doesnt work on these cars tho..
i would just change it and see if it works but the missus is a female... self explanitory
monkey
Donating Member
Good to hear lol. Just change the shafts mate its sounds very likely to be the solution. Then if you manage to stuff it up just tell her barinas are the work of the devil and shes much better off without it but at least she still has you, hopefully.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Have a look and see if there's a stone caught in the tyre tread.
Don't laugh.....It does happen.
Immortality
Staff member
Sth Auck, NZ
C.V's normally do the clicking thing when cornering as they wear out.
Stone in the tyre is also a definite possibility. Stone trapped in a brake calliper is even worse but that just squeals :(
Brisbarnz
Vh sle
I've got same prob in a laser. Got new cv's still clicks, tried new wheels n tyres still clicks. My solution is to ignore it. It's just a ford.
speed__demond
slammed and cammed
vic
vs statesman 5L
sorry bout the dig, haven't got to fixing it yet.
mate recons its carrier bearing in the tranny..
I think its cv. anyone had a carrier bearing make a loud click every revolution?
Calaber
Nil Bastardo Carborundum
Lower Hunter Region NSW
CG Captiva 5 Series 2
Replacing front half shafts isn't normally very difficult and the sound you are hearing is more likely to be a cv joint than any of the other suggestions (apart from the trapped stone). If you try turning through complete circles or the figure eights like earlier suggested at low speed in a quiet cul-de sac, with a smooth road surface to cut down on tyre noise, the noise will be most apparent and you can isolate which cv is shot. I doubt that a carrier bearing will "click" as it only rotates on a single plane whereas the cv rotates at varying angles under greater load. If it was the carrier bearing, it would be more likely to grumble similar to a wheel bearing.
