ssn8r
- Feb 9, 2006
- 94
- 0
- 0
- Age
- 42
- VN SS Supercharged
ITEM: T56 6 speed Hydraulic gear box (Borg warner)
DELIVERY/PICK UP INFORMATION: Pick up available, delivery at buyers expense
PAYMENT OPTIONS: COD, Direct Deposit.
CONTACT DETAILS: Moe 0409 966 626
CONDITION: Used
Selling my Borg warner T56 6 speed box out of my vn ss as I am stripping it away and selling the lot. This unit is a Hydraulic setup, so it is very easy to set up and much more reliable than a cable setup.
This kit will be a complete bolt up kit. Clutch and the flywheel were only just balanced and run in before car going off road for rebuild. You should not need anything further to add or replace once buying it is a full kit if your car is a VN-VS
INCLUDES EVERYTHING YOU'LL NEED:
- T56 6 speed Hydraulic gear box (Borg warner) with bell housing to suit Holden EFI V8
- Harrop steel explosion proof flywheel
- Custom 5 puk exedy cerametallic cushion sprung clutch
- Valeo pull type pressure plate rated at 1800kg good for 900hp-1000hp,
- Billet short shifter
- Balanced tailshaft
- Series 3 hydraulic pedal box
- Hydraulic lines and fork adaptor to gearbox perfect condition no leaks
- Reservoir and pedal box connector through to hydraulic line
- Factory gearbox leather surround with console unit
- Speedometer calibration module to adjust and calibrate your speedo
- Gearbox rear crossmember
The custom clutch, flywheel and pressure plate alone cost me about $2,000.
Inspections welcome at certain times of the week by appointment only.
This is a complete full kit, and more importantly - hassle free conversion. Bolt it in and calibrate your speedo and you're good to go.
Selling at $5K as a complete kit. Text or call me on 0409 966 626 if you want to chat or enquire about this box or make a best offer.
Location is South East VIC. Prefer pickup however can courier at buyers expense.
ITEM: Genuine VN SS Group A interior
CONDITION: Used
Up for sale is a genuine VN SS Group A interior. Velour bucket style and beautiful trim. Regretful sale as I would have loved to use this in my future cars if i had another Holden VN-VR but unfortunately I don't have a need for it anymore.
Given its age the trim is in overall excellent condition for a 25 year old interior.
They have come out of my car which is unused for sometime, about 6 years so they're little dusty could and do with a vacuum.
I believe $6K as a complete trim is a reasonable price to start with. Text or call me on 0409 966 626 if you want to chat or enquire about this interior.
Location is South East VIC. Will courier or post at buyers expense anywhere around Australia.
ITEM: IC&E Ignition system kit
CONDITION: Brand new
IC&E ignition system comes with 16 volt ignition booster, 4200 series ignition coil and 7000E 7A ignition module.
Not needed. All are new. Never used! Only dummied up one module which is the one without the plastic wrapping: Booster 2316. Still have the fresh new loom for them etc. Will Post at buyers expense. Essential to have for all V8 high performance builds.
Paid around $730 as a complete. Selling for $650 or best offer.
CONDITION: Used
CONDITION: Used
