[VIC] Fs: Lumpy ecotech cam
taztassio
VY S L67
Hey,
I have a BRAND NEW BILLET CAM TECH cam, specs as shown:
Advertised duration: 290in/290ex
duration at 0.050": 229in/229ex
Lift at Cam: 332"in/332"out
LSA: 110
intake centreline: 108
For stock heads this will need modified retainers, as its about 532" lift in and out.
Located glenwaverley, will post.
$550 no lower
(cost of grinding this custom cam was $550, and the cost of the billet ontop was more).
This will idle rough, and produce some mean top end power.
H1GHROLLR
CHEMICALLY SUPERCHARGED
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
thats not a very lumpy cam the LSA:110 is very very tame
greenfoam
VP Executive R-spec
In a ls1 maybe.... but that's getting right up there for the V6's it would be VERY grumpy at idle
chargedvx6
VY SII HBD Calais L67
Yeah the LSA is 110 but did you check the duration? 230? Great top end from this thing if it's tuned right
taztassio
VY S L67
ahah this is NOT a tamed ecotech cam.
call camtech yourself. this is a CUSTOM GRIND, for 3-5000 rpm, rough idle. its all written on teh card.
you can do the cam yourself, but it would be in the range of $400-$800 to get installed.
This will produce some MEAN power for someone serious about their ecotec.
to give you an idea, stage 3 intense cam has specs as follows
CAM-363 - INTENSE™ Stage 3 Normally Aspirated Cam, duration @ .050": 222º/230º, lobe lifts: .339"/.331", valve lifts with 1.60:1 rocker arms: .542"/.529", lobe separation angle: 110º, intake centerline: 106º
This cam as MORE intake duration, and very similar lift
here is a vid of a STAGE 2 in a car in the US with a reasonable size exhaust
http://www.intense-racing.com/video/WesCamMov.mpg
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
the ramp rate of the lobes has a lot too do with it to and just looking at that cam sitting there it has a fast ramp rate be nice and choppy i bet. very nice looking new billit too
taztassio
VY S L67
delcowizzid hit the nail on the head.
this is why i posted a picture, so people SERIOUS about ecotec power will get a good idea
17UCK!
vs III commodore ute
i would totaly buy this but ive already put 1.95 rockers on :( sounds sick tho
