cam is BRAND NEW never installed.
stock lifters are hydraulic roller, so they will be fine, just setting up the preload on them will be your concern.
i would run MINIMUM 105# valve springs, and you will need either VITON valve seals or MODIFIED retainers to allow for the increased lift (seals are about $30 from states, and retainers are about $70).
this will produce great power, and is probably the biggest you can run on stock heads. i am not going to claim a KW increase as there are so many variables.
also, pushrods will be needed.
on 1.6 rockers you will have 532" lift in/ex. max the heads allow is 520". so modified retainers give you 30" more clearence, and the viton seals give you 20". thus either/or will be under 520" and allow you to run the cam.
also suggested a double row timing chain if you run more than 105".
also, rockers can be sold straight up for a good price, this will give you MORE of a power increase than rockers. as not only is the lift more than 1.95's, the duration is what gets the power. (how long the valves are open).
this is an absolute steal for someone wanting a great cam. the billet+delivery etc add a couple of hundred onto the cost of the grind ($550) and im prepared to wear the cost of that.
With rudds money coming in for most of you, put it to a needy cause, your car
