DeathSammich
Hobart, Tasmania
VT Berlina S1
I have an l67 and it uses a decent amount of fuel. At idle in park qhen warm uses 1.9-2.2l per hour on the display and in drive uses 2.2-.2.6l per hour. I've read it's meant to read around 1.6? What things could effect my idle usage? I think idle usage pretty much reflects driving usage which is also fairly high. Thanks.
Immortality
Staff member
Sth Auck, NZ
HSV VS Senator, VT s2 Exec, VX Calais II L67
Maybe a touch high. I see 2-2.4 depending on how hard the AC is working.
Have you fixed the loss of compression yet?
DeathSammich
Hobart, Tasmania
VT Berlina S1
My AC is off. Compression is fixed. I got a wideband in and my fueling seems somewhat okay but when cruising it keeps swinging from the 13s to 14s.
Immortality
Staff member
Sth Auck, NZ
Was it the head gasket?
Sounds like the tune is off and possibly not going into closed loop mode as it should be seeing 14.7:1 when cruising.
Depending on what WB O2 kit you have and how it is wired in it may be off a touch, best bet is to get your tuner to compare the WB O2 to the standard O2 sensors and see if they read the same when the PCM is operating in closed loop mode.
DeathSammich
Hobart, Tasmania
VT Berlina S1
Nah the valves weren't sealing
Alright cheers
