Fuel consumption/tank size
samueljm
VR Executive Wagon
Hi All,
I recently bought a 93 VR wagon executive, auto, 3.8. It's sitting outside my place, not starting , and it sounds like it's run out of fuel as I can hear the pump. Now, it's done exactly 405km since last full fill, which, if my calculations are correct (no guarantee!), puts its consumption at around 16.9/100km, if the tank is 68L. This seems awful high, even for city driving (which it is). Apparently it is supposed to do 10-13L/100km, or give me at least 520km from a full tank. Anyway, I was expecting to get at least another 100km out of the tank, which explains how I got caught out without fuel.
The fuel gauge is working, but seems to go very quickly from 1/4 full to empty very quickly compared to fuller stages.
(No fuel on the ground).
Now, I've been a pretty conservative driver, as I wanted to see how much I could get out of a tank. No excessive revving or accelerating.
Does anyone know why it seems so inefficient? Or is this normal? Or does anyone know if the fuel tank is actually quite a bit smaller? The numbers would make more sense if it has a 50L tank... Could it have been changed (wagon has been lowered, and has replaced exhaust)? Any ideas?
A hearty thanks for any advice.
-=ApheX=-
Ya mums house!!!
VS 3.8l Exec
you can't really take good measurements on fuel usage for the simple fact that there are alot of contributing factors involved. e.g. How you drive it, weight your pulling in and out of the car, how well it's been kept serviced, if it's out of tune, etc.
What I would suggest is if your keen to get far better fuel econamy then a few simple things need to be followed.
A Major service; Plugs, leads, filters, oil, coolant etc.
A deeper search; Fuel filter, injectors, clogged throttlebody, stuffed O2 sensor etc.
do an error code check
Then fix errors,
If all is good then proceed with eliminating possible causes of excessive fuel use.
Once you've done as much as you can take it to a well established mechanic for an opinion only, then get a second opinion. Then decide to get a major service.
That's what I would do.
Good luck
AussieHuddo
Aussie Huddo
Baulkham Hills, NSW
VR 3.8 A4
sounds about normal for city driving...especially in a major city. the v6s get great fuel economy on the road tho like mine got 7.9L/100km to melbourne and back.
also mine drops from 1/4 to empty faster than fuller stages but thats just the cars own personality...you just gotta learn to live with it
wildeagle44
VS Acclaim
68L tank sounds about right, but 16.9/100km sounds high so it may need a major service. How many k's on the odo?
Hams
Newcastle
VS 5speed
i have to say that i have the same problem, i own a vs 5 speed and im getting around 300-350km's out of a full tank.
it was an auto but was swapped over, i found out that i was running an auto ecu and only getting around 300km's, so i got a manual ecu but still getting a **** 300-350km's
i have been told that the fuel tank breather hoses could be old and cracked? letting the fuel vapor escape? any truth behind that?
Brett_jjj
Tamworth NSW
vs commodore
Keeping the filters changed regularly,oil,fuel and air will help to get good economy.Also keep the Auto trans serviced.The filter and oil in the trans are easy to do yourself.I do mine every 15000k's,I do the engine oil and other filters every 5000k's.Filling the fuel tank,especially around town just wastes fuel as you have to drag around all the extra weight.Just fill it to half full around town and you will use less fuel.Extractors always make the engine run more efficiently.Definitely worth getting.And tyre pressure,run them at their maximum pressure.Also make sure the brake system is in good condition.If neglected it can end up with the brakes dragging on the disks.Not good for fuel economy.
VS_Pete
Donating Member
I run my tyres at 36psi
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Your fuel consumption sounds about average to me and I think unless you can do all the work yourself, like plugs, leads and filters yourself, any savings in fuel will possibly be less than the cost of the servicing.
The way I look at it is that your car has been pounding the bitumen fo 17 years and umpteen thousands of kilometres.....you cannot expect peak performance after 17 years unless you want to spend many dollars with sometimes no guarantee of return.
Brett_jjj
Tamworth NSW
vs commodore
I keep my car serviced and I get excellent economy.If you drive around with a blocked up air filter or fuel filter and you will soon see the drop in economy.
gandelff
vt
i have a vt v6 and have just finished the maths on its fuel consumption .think i am getting 10.79 ltr per 100 k if my tank is a 68 ltr dose that sound about right ?... i seem to be getting 640 km from a full tank it seems to good . i do highway runs sumtimes but still ?
