Fuel control module.
Grunna
52
Forrestfield
2003 VY LS1 UTE
Hi all,
I have a 2003 VY series 1
LS1 6 speed ute....
Just did cam and valvetrain, bolt ons already there. This is destined as a burnout vehicle only, not road reg. Tuner has done his thing, BUT, and afew other tuners have come accross the same thing......
He can increase fuel over different rev ranges, but cannot from 5200 to limiter.....has anyone bypassed the fuel control module or did something else to rectify this...series 2 and VZ were different....any help?
07GTS
Australia
VEGTS BUILT BLOWN E85
LS1 uses a mechanical fuel pressure reg, if u cant add fuel ur either out of injector or pump or maf has hit limit or are u mafless? what is fuel pressure? and injector duty cycle ?
Grunna
52
Forrestfield
2003 VY LS1 UTE
Cheers for reply...yes its mafless....
I was only told fuel pressure is good, but not given a number......
Also told the injectors will be fine without going bigger with the setup i got. I do have a fuel pressure gauge at work which i will see if same fittings and bring home to test numbers.
Thanks
07GTS
Australia
fuel pressure should be 58psi
Grunna
52
Forrestfield
2003 VY LS1 UTE
Thanks...i will test.
It was fine with stock cam with bolt ons....now we need more fuel and theres a problem somewhere
07GTS
Australia
shouldn't be any limits in the tune fuel wise, unless something real odd was done i guess, id be checking all mechanical stuff first just encase
Grunna
52
Forrestfield
2003 VY LS1 UTE
Thanks.....might have to look into another pump for starters......
Grunna
52
Forrestfield
2003 VY LS1 UTE
sorted...it was in the tune....hiding in a different spot
cheers all
