Fuel Damper?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by dans_vz, May 14, 2011.
  1. dans_vz
    dans_vz Active Member
    Swan Hill
    MY16 VFII SSV Redline Manual & 05 VZ Calais daily
    Do I need a fuel damper on my VP V8? I notice that in the gregorys manual there is a fuel damper on the fuel line but I dont have one at all on mine?
  2. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    If the factory fitted them, then it probably needs one..There would have to be a good reason why they fitted them in the first place..
  3. yxyx64
    yxyx64 New Member
    nsw
    Kia turbo + Holden badge, Chev badge in Texas
    on a vr v8 the damper is located on a bracket on the cylinder head as part of the fuel supply pipe just before the fuel injection rail. It is a can with an inlet pipe and an outlet pipe. You can blow straight through it. So what happens when it is removed? I took mine off for a while and felt no difference at all (took it off as I could not buy new bent fuel hoses that would fit it when the original 20 year old hoses finally gave up). Put it back on a month later and could tell no difference (and I run a 355 with 890 injectors so it sees plenty of fuel going through it)
