Hi all, I am currently trying to fix my fuel filler door and I am unsure if there is a bit that has snapped off at some point as it is no longer staying shut. The latch seems to be working properly. Just wondering if someone could post a picture of their door as I can't really find any that show it clearly. Thanks in advance
Looked at a mates last night and it turns out it is the latch isn't sticking out far enough. Is it possible to adjust this, if so, how?
Maby either get some lube on it, it may be just getting stuck. Or, Have you looed at the door?, No brokem pieces where it slide's in? More often than not it's the door that brake's. Just where it slide's in. < this part brake's and will not grab. <may need to add lube to this part so it slide's in and out easier.
Yeah the door is fine, its the pin in the second picture, it only comes out to just after the angled bit, i'll give lubing it a shot Thanks mate
