I was wondering if someone can tell me where the fuel filter is on a Vr comodore
B beno Guest Feb 13, 2004 #1 I was wondering if someone can tell me where the fuel filter is on a Vr comodore
Darren Administrator Staff member Joined Feb 2, 2003 Messages 3,002 Reaction score 428 Points 83 Age 44 Location Adelaide Website www.justcommodores.com.au Members Ride BYD Atto 3 / RAV4 Hybrid Feb 13, 2004 #2 The fuel filter is located at the rear of the vehicle under the wheel arch on the drivers side. Perhaps not the best wording to describe it's location but that's all I could think of at the time. I've found the easiest way to get to it is by using some car ramps. Make sure your using protective glasses and depressurise the fuel tank otherwise you'll swallow a fair bit if your not careful.
OSL-060 Banned Joined Dec 23, 2003 Messages 1,298 Reaction score 7 Points 0 Age 42 Location SE QLD Feb 13, 2004 #3 What Darren said plus..... Undo both clamps so it's ready to come off, wrap a nice big rag/blanket around the hose on the tank side or even the whole thing. Then remove Sounds like overkill but it stops you from getting a face full of fuel, you'll get some on you regardless but the big rag limits it. Cheers and g'luck Jake
OSL-060 Banned Joined Dec 23, 2003 Messages 1,298 Reaction score 7 Points 0 Age 42 Location SE QLD Feb 13, 2004 #4 Another thought... The fuel system can be depressurised by starting the car and removing the fuel pump relay.. Doesn't have to be done, in my opinion it makes sweet FA difference. Cheers Jake
S stheggie New Member Joined Jun 16, 2003 Messages 106 Reaction score 0 Points 0 Age 39 Location Bundoora, Victoria Feb 17, 2004 #5 Same as what he said above however, I started my car, pulled the fuel pump relay out... let it stall. Then turned the key and turned the engine over for about 10 sec's After doing this i found that only a very small amount leaked from the pipes, Just a thought Seeya!
