fuel filter
gungazza
65
west suburbs
executive vt 5.0lt VZ CREWMAN
so here we go again , tried to undo the clip on the filter will not budge looks like some one has stuffed it be fore one side has a hose clamp on it have used the tool that slips in but will not budge how do I get this off without stuffing it thanks
I have some pics but cant put them up for some reson lol
clicking manage attachments but nothing happening
2O4TS
Qld
VT 9C1
You don't need "the tool" to undo the hose from the fuel filter. You squeeze, wiggle and pull.
I had a hell of a time getting mine off too and bent a tang because I thought I needed to use the tool as well. Consequently it leaked when I replaced the fuel filter. I replaced the hose (a "U Pull" style wrecker just gave me the hose, pump to filter hose that is, after I removed it) but you could use clamps.
accentstencil
69
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
Push hose connector towards the filter, squeeze the two tangs then pull away from filter. Some force might be required. Don't forget to de-pressurise the fuel system first.
ConstantVelocity
ACT
VTII SS M6
Clean any dust/dirt off as best you can then blast with WD-40, makes it much easier.
accentstencil
69
Eschol Park, Sydney
Looks like someone attacked it with multigrips or something. The tangs don't stick out very far anyway so try squeezing where the tangs should be.
gungazza
65
west suburbs
mm not looking good may have to replace hose ill have another lookat it tomorrow fingers crossed why do people stuff things up like this
2O4TS
Qld
VT 9C1
Cos they don't come on to JC first! :D
BlackVXGTS
Melbourne, SE
Provided you have the correct tool (for the size of the filter pipe), push the tool into the fitting, then push the fitting and the tool towards the filter and then pull back in the opposite direction. Usually works first time. When you replace the new fuel filter, put some engine oil on both ends of the filter that fits into the connectors. That will make it easier to disconnect next time.
Keegzzz
27
Carlingford
Vt Calais
I did my filter like a month ago, you don't need the tool, i wrestled with it but eventually got it off. Don't be gentle but be careful about your movements because you don't want to wreck the line.
