FUEL Guage Error
Paloo
Somerset (7322)
VZ Crewman X6
Hi
I have a 2005 VZ Cross6 Crewman. 225k done.
Won't start showing
  • Very low fuel
  • Service vehicle soon
  • Fuel gauge error contact dealer.
I assumed ECU fault and my mechanic said the ECU doesn't show up on their scan tool.
Should I be doing any other troubleshooting prior to buying a used/new ECU?
Any recommendations for mechanic or auto electrician would be appreciated. (In North West Tasmania)
BIG_JV
Australia
VZ Wagon
Had this with my VZ and it was the ECU. One way you can try get it to start is to reset the ECU by disconnecting and reconnecting the earth wire. It screws into the chassis just below where the master cylinder bolts on. It is the middle bolt in this photo below.
So just unscrew it, seperate the earth from the chassis for a few seconds (maybe clean the earth site) and then reconnect it and it should start right when you turn the key afterwards. If this is the case, it's most likely that your ECU is cooked unfortunately...
Paloo
Somerset (7322)
VZ Crewman X6
Thanks. I did try that but no go. Auto electrician said ECU is fried. They put new ECU on and now the PIM won't accept. Their main techs are looking at the PIM but they have a backlog of work so I have to wait a week for the verdict. Will post the outcome.
bertreb
69
vic
VZ, V6 commodore
Hi
Won't start showing
  • Very low fuel
i have the same problem with vz wagon, just happened few days ago, got stuck at shops, but finally started, drove home, now nothing. what was your solution?. any suggestions welcome. thanks
Jolls
Donating Member
Murrumbateman
VY SS Ute (Jimi Hendrix)
Hi Paloo
I am in the same position in relation to replacing my ECU. The ECU needs to be linked to the PIM. If you have the codes it whould be a faily straight forward proceedure. Says me who purchased a VCX Diad nano that can't see the modules and had a frineds Snapon Scan tool hard drive fail in the middle of the linking proceedure. I trust yours goes much smoother.
Fu Manchu
WA.
It might be possible the linking procedure was not done correctly and the PIM is just doing its job.
N O T E
Prior to resetting the ECM, obtain the Security Code and the BCM Security Number. This information is found on the vehicle security card issued with the vehicle when new.
• 1. Connect Tech 2 to the data link connector (DLC) and turn the ignition on.
• 2 On Tech 2 select Engine / Programming / Reset ECU.
*N O T E
When Tech 2 requests programming approval, obtain TIS approval.
•3 When Tech 2 displays Enter Security Code, enter the security code, press the Enter key and then the Okay soft key.
•4 When Tech 2 displays Turn Ignition on, press the Confirm soft key. After resetting the ECM, the ignition switch must be turned off for at least 10 seconds then turned on for at least sixty seconds, before commencing communications between TECH 2 and the ECM.
•5 When Tech 2 displays Reset Completed Successfully, press the Confirm soft key to return to the Tech 2
Programming screen.
