Fuel guage
ant797
bunbury
vy s
Could try put some injector cleaner in the tank and fill the tank up if it's stuck it might clean the sender ...or it might be a guage or earthing problem
Polaris
QLD
VY UTE 3.5L
Is it an original fuel pump (assembly)..? If so I would first check grounding as ant797 suggested.
Next to check is just tap the bottom of the tank - if you can see where the return line or pressure line start with some light taps with a rubber hammer along that axis.
The idea is that the fuel pump assembly sits on the bottom of the tank, so two things can occur..
1) the float arm free's up if stuck
2) any electrical connection that's gotten loose over time in the assembly settle back in place or come off - ether way you know it's where the issue is.
Note , don't bash, just tap - the plastic is old and can be a brittle by now.
07GTS
Australia
VEGTS BLOWN E85
when sender fails can make gauge read full scale, check ohms to sender its prob O/C
krusing
Melbourne Bayside 3193
Maybe the Float has fallen off the Sender arm, or the actual unit,
Still sounds like a Drop the Tank out job either way.
Its not a hard job, just time consuming.
Edit: Check onboard computer menu, that may also assist.
TheIceman
VY Ex-cop
My fuel gauge is permanently showing full
mine was going off its head again the other day, dropping to zero fuel from half tank then goes back up to half again for half the day and settled down.
07GTS
Australia
VEGTS BLOWN E85
some had the opposite reading senders in them so some when they fail will read full and some will read empty
