refvpsenator
- Dec 31, 2016
- 30
- 21
- 8
- Age
- 77
- Location
- townsville
- vp senator
G'Day, I have a problem with my VP Senator and looking for some advice, please.
My Senator would not start and I could not hear the fuel pump working so I took the tank out.
The tank had the two 3/16 lines broken completely off and I think this was the reason fuel ran out onto the servo driveway last time I completely filled the tank
When I moved it I could hear something rolling about inside. After removing the pump and float unit I removed a piece of fuel line that runs from the return line to the base of the tank. If this interior fuel line is broken will it stop the motor from starting or doesn't it matter? There is about an inch of fuel line left on the inside of the tank. The pump access hole is only 60mm so no access to the inside to replace hose. I do not really understand the workings inside the tank. Thanks Gaz.
