My l77 does not have bosch , it has ac delco injectors .I skimmed through, but did not see the part number of the 2015 L77 injectors by Siemens?
All L76, L98, LS3 and L77 are made by Bosch, GM part number 12576341, Bosch ID# 0280158051 42#
OK, I think Bosch make the injectors just like the spark leads and O2 sensors, NGK make the plugs, Cloyes make the timing gear, Delphi makes the lifters, etc.My l77 does not have bosch , it has ac delco injectors .
Mine is 2013 calais not sure of the month . These are the ones i get from america .OK, I think Bosch make the injectors just like the spark leads and O2 sensors, NGK make the plugs, Cloyes make the timing gear, Delphi makes the lifters, etc.
I think they are all available though AC Delco, which used to be a division of GM like Mopar or Motorcraft.
Can you tell me the date mm/yy of your car manufacture, as it seems the injectors you ordered supersede the Series II VE and perhaps it is those which are now causing problems through failure.
Thanks for that, just trying to nail down the break when the (non-failing) injectors were revised from 12576341 to (failing) 12639221.Mine is 2013 calais not sure of the month . These are the ones i get from america .
Just read “bent pushrod” on a factory motor with hydraulic lifters and low ramp cam... nup. Did you have the rockers replaced per chance?Got call back today, Holden are replacing all 8 injectors under good will. Also got told I have a bent pushrod in cyl 1.
I know for a fact that was not done by me, car has always sounded a little rough, now I know why.
Car should be back on the road by friday
