Yeah this is the only issue. Handles fine under heavy load, given it a few squirts lately to see if anything happened but it’s all fine. It’s a little hard to test the priming because it only happens randomly, for all I know it might not happen again until Holden looks at it and it probably won’t haooen when they look at it tooNot much help I know. But it definitely sounds like a fuelling issue to me. It's turning over fine and seems to be firing. Is this the only issue? Or, does it exhibit any other issues under various driving conditions?
Does it do the same thing if you let the fuel pump prime the system first, I.e not remote start?
It's like initially it has a bit of fuel, but not enough to start. Then when the pressure builds up, it fires. As others may have said, it's like nearly all the fuel in the lines is bleeding back into the tank (= no pressure at start up). If it was a faulty pump, it would miss or stall etc under load.
An apprentice mechanic at work said it could be the starter motor, can you explain more about this ring gear?Has anyone said starter motor? Kind of sounds like the starter isn't disengaging from the ring gear properly..
I think its called a solenoid, if l remember correctly. Solenoid over run.Not everything fails instantly or completely. The starter motor has a little gear that moves forward to engage with the ring gear on the back of the engine to crank the engine. If the starter is faulty and the little gear doesn't always retract fully after starting it could be grinding on the ring gear until it gets knocked clear.
Insert correct technical terms here if you like
