fuel preesure regulator?? syptoms?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jas98, Dec 24, 2011.
  1. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    hi, my vs is getting hard to start first thing in the morning or late at night after been sitting for say 6 or more hours (night work), it cranks over for about 3 seconds then fires but when hot it starts first time but when cold and it starts can smells fuel smell and soetimes if in an enclosed arear like a drive through at maccas etc it has a slight smell to. i took the vacum line off teh regulator and there was some oily sludg in there when i put my finger over the vacum inlet on the regulator. also caoul smell a strong fuel smell mixed in witth the oily stuff and the hose smelt a it like fuel
    anyway is the regulator stuffed? injectors have been replaced although some orings are leaking i will be fixing tha in a few days but it was doing this even before i put different injectors in
    cheers
  2. strgas
    strgas GRA = REAL HP
    sounds like your reg is leaking fuel into the manifold thru the vac line and the black sludge will be the perished rubber , replace the reg and your troubles should be gone along with improve fuel economy and better starting
  3. jas98
    jas98 Active Member
    maryborough QLD
    cheers mate, yeh thort so, i got a spare reg here however its been cut off but i cant see why i cant just use some EFI hose and a couple of good hose clamps?
    cheers
  4. VS_Pete
    Yes you can.
  5. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    I did the same with a VT wagon...buy quality clamps if you can find them and used 2 at each end.
