Anyone had this problem, my vs is getting spark and everything but wont kick into life, seems as though it isn't getting any fuel through, does it seem as though it's just a fuel pump problem, or something else, any advise would be helpful.
Is the immobiliser light still on when you try to start the car? - it's the flashing red light above the radio. Can you hear the fuel pump prime for about 1 second immediately after you turn the ignition on? Is you battery fully charged - a slightly flat battery will not start a VS....they will crank but not start.
Ok cool, you could be spot on about the battery thing, it had lost a little charge due to another problem which i was fixing on the day, thanks mate I'll recharge the battery fully and give it a go, cheers
