Fuel Pump flow rates
Mr Ute
VR HSV
Dose any one no what the flow rate is for a VR 5.0 std fuel pump and are they the same as the 6cyl pumps.
Thank You
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Ellery says 1.25Litre/30sec (24g/sec) @ 240Kpa for VR
Doesn't differentiate between 6 and V8
Cannot find anything on flow rate in the Gregory.
You'd think they'd be different for V8 and 6.
Mr Ute
VR HSV
Well i been looking at the diferent kinds of pumps and like you said the 6 and 8cyl are all the same.kind of weird.
Thank You very much for the information it helps alot when looking for a new pump.Im thinking of going to a external pump with a serge tank as i have noticed when flying around a tight bend under load it tends to lean out a tad and lose power.
Thanks again
jason
