fuel pump GRRRRR
damage17
Rye
VT 3.6 ecotech
Can anybody help I need to know if there is a way to check the fuel pump before i put it back into the tank just to make sure ??
Dayvo
Because i can
64
South East,Victoria
VE SV6 Series 2
Try connecting the negative and positive terminals of the pump direct to the battery
damage17
Rye
VT 3.6 ecotech
thanks thought that might do it but was just a bit tentative
damage17
Rye
VT 3.6 ecotech
no problems now after an initial splutter and removal of crap works like a dream and all this after being told by auto lec the pump was shot. Goes to show it pays to double check......
naf33n
go
The Shire
Supercharged VU SS
have you refiited it to a car??? just cause it spins and makes some noise doesnt mean it will work in a car, injectors need pressure, and if the pump cant keep up you wont get it to run.
if you have refitted it and it works.. all good
ari666
250,000 hits
mate, it needs to go into a bucket of petrol and tested. also, once they have been used they need to be stored in petrol at all times, cos the seals inside dry out. then the pump will spin up no problem, but it wont pump dick all.
Brett_jjj
Tamworth NSW
vs commodore
Gotta test the flow rate and pressure rates to get an idea of fuel pump condition.The pump will overheat if its operated out of fuel,It has to be submersed in a bucket of fuel as mentioned above,the fuel cools the pump when its immersed in it.This is why these fuel pumps can crap themselves when these cars run out of fuel,some people,once theyve run out of fuel,wind over the engine trying to start the car again and all the while the ignition key is on,the fuel pump is running whilst dry,the pump usually craps itself if this is done for too long .Ive seen a couple of these pumps die this way when dopey drivers have kept trying to restart the car once its run out of fuel..
