Fuel pump recommendation
Adrian Collins
62
New Zealand
Vn engine fitted in cf Bedford
Hi. So I am busy putting this vn commodore engine in my Bedford cf camper and I am starting to think about fuel. Petrol. Can anyone recommend a fuel pump that I can fit external to my tank and how best to hook it up. Cheers
woteva
NEED 4 SPEED
Adelaide S.A.
Bosch 044 or equivalent.
They come standard on the VL 6 cylinder
Trevor loves holden.
vs commodore
Depends on your old Bedford tank, set up, how deep and the fitting section, probably easier just to remove your tank and fit a commodore tank, might need to make up brackets.
Adrian Collins
62
New Zealand
So what are the thoughts about fitting an external fuel pump? Or does it need to be an internal one?
woteva
NEED 4 SPEED
Adelaide S.A.
Go for the external pump as it will be the easiest. You won't fit a Commodore tank anywhere under a Bedford.
Have a look on YouTube "The Skid Factory". They put a Barra turbo in a Bedford last year.
Not sure what episode, they did use the original tank and installed an internal pump.
Vin999
SA
VSedanS
Its episode 5 where they convert the bedford original fuel tank
Vin999
SA
VSedanS
Using the vn pump that is standard to the vn engine your using is a no brainer and a good start.
Vin999
SA
VSedanS
Fuel system/tank/fuel pump/filter/pressure regulator type/s and what to use would depend on whether your going EFI or carby ???, you didn’t say which ???
MikeC
VQ Statesman
I don't see any problem with an external pump, provided it has good priming characteristics ie can suck fuel well or is mounted below the tank's minimum fuel level. On a Triumph TR6 I have Carter Universal priming pump feeding a high pressure Bosch 058. A lot of Bosch pumps are hopeless at priming.
Adrian Collins
62
New Zealand
