swmcl
- May 8, 2015
- 22
- 0
- 1
- Location
- Toowoomba, QLD
- VE 2 sedan - ex police
Hi,
I have a 2011 VE dual fuel 3.6 V6 stock sedan that was a police vehicle. It is stock as far as I know.
I had an issue last week where I ran the kid to school and when I got home and then tried to go out again the car wouldn't fire up.
The car was then sent to a mechanic who charged the earth to find and replace a fuel pump relay. Then at my son's graduation the car failed again with the same symptoms 1 day later.
It is not the relay as such. I have traced the wires and proven the circuit is good surrounding the relay.
I can say there is only 2.5V being applied to the solenoid of the relay from the ECM computer. This is not enough to click the relay. I can say the car runs fine on fuel when I bridge the relay. I can say the signal from ECM to relay shuts down after the post-ignition clunking and whirring after the ignition key is turned off.
Q1. What is doing the clunking and whirring after the ignition is turned off ? There must be a motor and a solenoid involved in purging something or other ??
Q2. Could this clunking and whirring circuitry be supplying the voltage to the ECM for the fuel pump relay circuit ?? ( Given that the fuel pump relay is turned off after the clunking and whirring circuitry does its bit when the motor is turned off )
I have put a tiny amount of conductive grease on the pin of the ECM that goes to the fuel pump relay and also the larger positives (pins 3,5 & 6 of X2 connector) They should be OK.
I can't get to the back of the fuse panel in the passenger kick panel area - I don't know how to remove this fuse panel.
Any experience shared would be appreciated.
Cheers,
Steve
Cheers,
Steve
