Fuel Regulator
eagle13
42
Vx SS & VZ Crewman
Is it hard to change my fuel regulator as i have been told my is starting to go
auc05l
40
orange
VR Berlina V6
Easy as, bleed the pressure in the rail by removing the fuel pump fuse then starting the car. When the engine stalls pressure is gone. remove the return line from the reg, remove the vaccume line (I had to replace mine as it was eaten by the fuel that was leaking past the diaphram) then undo the 10mm headed bolt hoding the regulator to the rail. remove reg and reverse to assemble. Just a thought, holden are the only ones that supply the new o-ring you will require. I've just replaced the reg on my girls VR V6 and fuel usage went from 27L/100k's to 11!
quiksilver1
vu ss
where abouts is the fuel regulator?? i recently done fuel filter,how much should i pay to buy a regulator?cheers
struggo
Old Sydney Town
2016 VFII SSV Redline + 2013 FG MKII G6ET
Hi Auc05,
Are they the same on the VS & VR or different?
Struggo
eagle13
42
Vx SS & VZ Crewman
i just had one priced they are $130 brand new or around $40 second hand
TheForgotten
only human......
quarantine
www.holdenscene.com
VR EXEC
yeah that's about right. unfortunately they aren't as easy on a VS as on a VR. The guts of the above post is accurate, but there is a special tool needed for part of it. I'll look for more info and edit this post.
also, the problem with a second hand reg is there's nothing to say you're not gonna need to replace it again next week. unfortunately, they do just die with no provocation
auc05l
40
orange
VR Berlina V6
Follow your fuel rail around to the drivers side, it is simply bolted to the end of the rail.
Double G
VS Commodore
Would the fuel regulator affect the fuel usage from one rail to the other?
TheForgotten
only human......
quarantine
www.holdenscene.com
VR EXEC
no, it's one rail. goes in passenger side, across front of engine, down drivers side. all the reg does is keep a certain pressure inside the rail. anythin over this set pressure goes through the reg back to the tank
NeilB
65
VR Caprice
To make a tool for the fuel fitting just get a silicone lid and cut it to size about 2" long then slit it down the middle so it will go over the fuel feed pipe then just push it up to get the connection to release. Be patient.
