Fuel return hose / line
Kayne_L
Ulladulla
Vy
I need to get my fuel rail out in my v6 ecotec and I’m having trouble disconnecting the fuel return line from the fuel rail (not the end that goes into the metal lines) there isn’t a clamp or anything and I pull it but it won’t budge just wondering if anyone else has come across this ?
J_D 2.0
Ipswich
2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
Probably needs a special tool like this set. I’m not specifically saying that set will do the job but fuel lines on most cars have needed special tools to remove them for a long time now. If there isn’t an obvious way to remove it then it needs one of these types of tools.
https://www.supercheapauto.com.au/p...-fuel-line-disconnect-set-7-piece/123376.html
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Yes, that set will disconnect the fuel lines!
Here mate, here's a link to the vt - vz workshop manual.
Lots of use full information in it.
Fu Manchu
Get Off Your Phone When You’re Driving.
Western Australia
Kia Sorrento, VZ Crewman, VZ Cross 8 (VE Calais)
Yep. Special tool required. You’ll get it at any parts shop. They are cheap.
