Fuel Tank Leaking...Help me!!
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Leebo, Mar 20, 2009.
  1. Leebo
    Leebo New Member
    89 VN
    hey guys another result of poor fuel economy is probably the hole in the fuel tank which drips fuel all day long i would have to think.
    I put my hands around the back of the tank where the hose is connected on one side and felt fuel coming out, it's dribbling lowly.
    Does anyone know how i can fix this is leaking on the tarmac as is speak.
  2. plains203
    plains203 New Member
    VP Berlina
    Is it coming from the hose, the connection to the tank, or the tank itself?
    Work out exactly what is leaking. If it is the hose shorten it or replace it, the connection tighten the clamp or add another & if it's the tank take it to a mechanic to get sorted out.
  3. Leebo
    Leebo New Member
    89 VN
    yeah it's the hose which connects to the tank. do i need to get a clamp i can't see one in place. do i need silicon around it?
    Do fuel tanks rust or get holes that way cos i got no dint's?
  4. plains203
    VP Berlina
  5. Noy
    Noy New Member
    VN SS 5.0
    The hose might be buggerd, ild replace the hose and clamp and see how you go
  6. Leebo
    Leebo New Member
    89 VN
    You know how the seal in the windows for example dry out and don't work properly, could this be the same situation it that the hose is buggered and dried out then split?
    Do i need a new one or can a make one up from whatever i find?
  7. vg ute v6
    vg ute v6 Member
    vg ute v6 5 speed
    just check all the hoses first
  8. Cheap6
    Cheap6 New Member
    VP Exec
    From the description, it's likey it is the spigot for the return line is leaking at the tank. If that is the case, a proper fix would have the tank emptied and the spigot resoldered (yep, not a home workshop job).
    On a car that is not worth a great deal of money, alternatives are another tank from a wrecker or maybe a bead of one of the epoxy sealants made for the purpose can be applied around the base of the spigot.
  9. Leebo
    Leebo New Member
    89 VN
    Yeah i'll take it to a mechanic on moday.
    so untill then i hope nobody throws a cigarette under the
    back of my or BOOM!!!
  10. Lost_Pete
    Lost_Pete Member
    VN Wagon
    Don't try to use a sealant such as silicone as it won't set and it will be carried through the system to clog up the wrong bits.
    While you have the tank apart replace all the breather hoses with new ones.
  11. Leebo
    Leebo New Member
    89 VN
    Yeah i think petrol would eat silicone anyway. I dont wan't to be taking the tank off even because that's a whole lot of messing around. I'll replace the hoese first and see how that goes.
    I post how it turns out
  12. KnobMuffin
    KnobMuffin New Member
    VN Berlina 2L
    The most likely cause is a old hose, take the hose off and examine it for cracks. If it feels old and has a crack in it then it will need to be replaced. Also double check all other fuel hoses, there are a few by the tank and a couple in the engine bay.
  13. Johnsy
    Johnsy ★★★★★
    C/Town
    VF SS Wagon & VF SV6 Ute
    How did you go at the mechanics ?
  14. hellbound
    hellbound New Member
    vn Executive
    fule tank is a big problem. i would take it to someone who knows what there doing as well.
  15. Leebo
    Leebo New Member
    89 VN
    Haven't been yet i will let you guys know when i find out.
    thanks for asking
  16. Leebo
    Leebo New Member
    89 VN
    Yes i finally got it it was just a hose i replaced it and I'm sweet cheers guys.
