Fuel tank ponderances
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Cogez, Nov 19, 2006.
  1. Cogez
    Cogez New Member
    1993 Series II VP Calais
    G'day. I drive a Series II VP Calais, with the 63 litre tank. I've been noticing that when I'm running a little low on fuel (usually around 8 litres or less), my engine starts hesitating on acceleration, especially when I pull hard, or take off up hill.
    Does this happen to everyone (ie, is it something that this tank and fuel pump just does), or is there something wrong somewhere? If it is a normal problem, has anyone tried to correct it?
    Cheers guys.
  2. xcop5l
    xcop5l 4th year spanner spinner
    ol' geelong vic
    VN ex cop 5L
    from what i understand the fuel pump starts pumpin air rated fuel and you dont get as much fuel into the cylinder
  3. J_D
    J_D New Member
    Ipswich. QLD
    VN S1 and VS V8 Statesman
    Fuel injected cars should never be run below 1/4 of a tank because the pump uses fuel to cool itself and should be submerged at all times. There is no problem with it you just shouldnt run it with such a small amount of fuel in it.
  4. Full Spectrum
    Full Spectrum Bro it's a VW your Audi!
    Berlina V6
    Has your tank got any dents in it at all? My tank runs out before red it's got a nasty dint.
    My mates old VR berlina ran out with 30km left it also had a large dint in the bottom, Could be that?.
  5. J_D
    J_D New Member
    Ipswich. QLD
    Mine has some big dents in it, and ive run mine on the red line and didnt run out(on the first drive to the servo after getting it registered). If the dent is directly under the float it will be a problem but if its not it will displace the same amount of fuel to push the float upward, the fuel guage will go down quicker but should still read nil when there is nil fuel.
  6. Full Spectrum
    Berlina V6
    Only works for people who have normal tanks but, And still noone on JC can work out what size tank i have, It's not 63 it's not 80. Runs miles over the full when filled and cuts off before red. It's larger then the stock executives but smaller then the V8's.
  7. greenfoam
    greenfoam New Member
    VP Executive R-spec
    There's more than 2 tank sizes man! I was reading about this not long ago with all the option code stuff
  8. Shortstuff
    Shortstuff Random
    2016 Golf GTI PP
    I don't have any problems running mine right down to an indicated empty, but I think my guage mis-reads as I can only ever get about 55 litres in when I fill up.
  9. Full Spectrum
    Berlina V6
    So what is in the middle? 71 do you think??
  10. crazyspoon05
    crazyspoon05 Penguin Whisperer
    VW Golf GTI (RIP The 'Bizta' VNVPVR Wagz)
    68 litre in wagons
  11. Full Spectrum
    Berlina V6
    I wonder if i got a wagon tank?
