fuel tank size
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by moff_man, Mar 5, 2009.
  1. moff_man
    moff_man operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    hello all again.....
    i have been having a few problems with my fuel gauge. i sorta fixed it bye putting a new float arm on it but now at 1/4 tank it just drops to empty, i know its the sender unit but i carnt buy a new one anywere.
    now rare spairs do new units but only for 85L and 80L tanks for sedans, i didnt think there was a 85L tank for the sedan or was there? so i guess my question is what size tanks are there ment to be. 62L and 80L or is there a nother 85L in the range also....?.....:bang:
    https://rsp-secure.com/Search Products/list.asp?name=FUEL&car_type=18A&shop_id=
    if i can not find a unit to fit my std tank ill look for a bigger tank so i can have a new sender unit? also will the 80L - 85L units work in the tank?
  2. ephect
    ephect Donating Member
    VS Acclaim V6
    i got my last sender off holden bout 1year ago for 63L tank
    apparently statesman caprice and utility and extended rage option fuel tanks vary in size. my book lists 63L for sedan and 68L for wagon. i know the long range tanks where 80L but havent heard of a 85L jobby.
  3. moff_man
    yeah i know they are no longer listed at holden, well on the system anyways. some dealers may still have some nos (new old stock) but the dealer i work at has none....
    i might try and track down a 80L tank, will come in handy for my long holiday im planing..
  4. Chirpstr
    Chirpstr A new project attack
    VR Berlina M5, VP M5
    Just remember the switch for the two on the back of the dash cluster if you do decide to go bigger ;)
  5. 1991_Vn2nV
    1991_Vn2nV New Member
    Gumeracha, Adelaide Hills
    91 VN Berlina & 03 VY Berlina
    VR Fuel Tanks:
    V6 Sedan: 63L
    V6 Wagon: 68L
    V8 Sedan: 80L
    V8 Wagon: 68L
    VS Fuel Tanks:
    V6 Sedan: 59L
    V8 Sedan: 73L
    Wagon: 68L
    Ute: 64L
    So yeah, no 85L tanks from factory.
    ephect likes this.
  6. 5T8M3NT
    5T8M3NT 'making a statement'
    Series I VS Statesman
    i picked up a second hand 63ltr V6 tank and put my original pump and filter from my first tank in that (as my original tank split) and i seem to be getting a wrong reading on my fuel guage saying i have half a tank after putting about $40 bucks worth of fuel in there when it was already just under quarter? :S
    maybe use original pump and sender?
  7. moff_man
    20 bucks gets me about 1/2 tank but i have no idea how much is in there from under a 1/4......
    the 80L unit on rare spaires is for the 75L tank for some reasion....still nothing new for the 63L tanks so im going to buy a seccond hand 85L tank and get a new sender.......
  8. greenacc
    greenacc Searching for the billion
    VE Berlina
    do the V6 fuel pumps fit straight onto a V8 fuel tank ? so i could fit one to my acclaim as a straight swap ?
  9. TUF UTE
    TUF UTE Dave
    adelaide
    05 VZ SENATOR
    i can calibrate your sender for 70 dollars
  10. moff_man
    my sender is burnt and worn out down the lower part of the unit so its catcus
  11. Fekason
    Fekason Fekason
    Penrith NSW
    Changed in claimed capacity only.
    The VR and VS tanks are the same. The only difference is that the VS capacity has been reduced to the capacity if filled to the first click, as recommended in the owners manual.
  12. VSIIBerlinaL67
    VSIIBerlinaL67 New Member
    VX SS M6
    you can use the standard sender just need the longer float arm and to flick the switch to 80 behind the cluster
  13. moff_man
    my std sender is stuffed but i have a good float arm from a vp (currently to get me self out of truble i have the orignal vr sender and vp float arm, this made the gauge work from 1/4 up but below is hopeless...) if i use the good vp float arm on the 85L sender unit it should be ok? all else fales ill just go and get a 85L tank from a sedan and get a new sender unit and be done with it.....
  14. 5T8M3NT
    so at the end of the day.. whats the best size tank to go for? and what sender...
    i think my sender might not be in level maybe, ive been on just under half a tank the whole day after a full day of driving although the guage does go up and down
  15. moff_man
    i dare say its stuck on the swerl pot, may need to remove and reinstall
  16. 5T8M3NT
    swerl pot, is that the plastic pot thing in the center of the tank
    i saw that when i put it in, i tried getting it inside that, where should it sit?
  17. Chirpstr
    The return line should connect up to a line that comes from the swirl pot.
  18. 5T8M3NT
    is this on the inside or outside of the tank?
    bcoz i have one line that it just blocked up with a screw as i dont know where it goes
    my fuel pump has two lines coming out of that which i have connected up, then there is one more to the left hand side of that (as your looking at the tank from the back) which i dont know what it connects upto?
    maybe thats my problem? or maybe its not in straight?
  19. ephect
    VS Acclaim V6
    are you talking about the fuel tank has 3 pipes coming off the top of it or we talking about hoses round the front where the pump is?
    there are 2 types of tanks, 1 with 2 pipes on top of the tank, and the other with 3 pipes on the top of the tank.
    i kno my VS V6 uses the tank with 2 pipes.
