fuel tank straps removal
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by slappedvr, Jan 23, 2009.
  1. slappedvr
    slappedvr New Member
    vr executive
    hey guys
    just wondering how to remove the 2 straps on the bottom of the fuel tank on my vr v6 exec
    cheers jordan
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    From memory you just remove the bolt from the rear of each strap and then it just swings down like it's hinged. Jack the tank up first of course using some wood to protect the tank. If you are removing the tank it is best done when empty.
  3. LightningVP
    LightningVP Donating Member
    VY II 5.7 SV8
    ^^^ That's correct, you will also need to unplug any pipes if you wish to move the tank, the pipes are very short...
