fuel tank??
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Beav, Jun 23, 2012.
  1. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Will a vn sedan fuel tank fit a vr sedan?
    Sorry if I put this in the wrong area
  2. M1NTVR
    M1NTVR New Member
    Cranbourne
    VR Commodore 3.8L
    yeah mate should do, but i think it might come down to weather its live axel or IRS but vn to vs is the same hope that helps :)
  3. ephect
    ephect Donating Member
    VS Acclaim V6
    Yes but, the breather holes are a little differnt, vn has an extra one.
  4. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    also the fuel return line is in a different location, if using the vr/vs fuel pump assembly that won't matter (just an extra hole to block up)
  5. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Ok I will be using the vr pump.
    But I have ultra tune putting it in
  6. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Vn tank was stuffed if I can't find a vr, a vs will work?
  7. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Ultra tune has found a fuel tank and will be fitting it. It's going cost $330 all up? Is this a good price?
  8. woteva
    woteva NEED 4 SPEED
    Adelaide S.A.
    What was wrong with the old tank ??
  9. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Leaking. Use stop leak for temp use, but tank is denting and ****. So I decided to put another tank in
