fuel useage
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by VTPREDATOR, Jun 28, 2008.
  1. VTPREDATOR
    VTPREDATOR New Member
    Warwick
    VE SS SPORTSWAGON
    how long do u think the v6 should run, running off a jerrycan? my v6gem drank the whole jerry can in a matter of minutes. it hasnt got the o2 sensor connected yet, but i dont think that should matter too much. only other guess i can think of is the aftermarket fuel pump might be pumpin too much pressure in.
    could that be a problem or should the stocko fuel regulator fix that?
    cheers,
  2. Lost_Pete
    Lost_Pete Member
    VN Wagon
    How did you set up the fuel feed and more importantly the fuel return.
  3. VTPREDATOR
    Warwick
    VE SS SPORTSWAGON
    as per normal, i would assume.
  4. immortality
    Sth Auck, NZ
    if it drank that much fuel in a few minutes (idling or driving?) i'd imagine it was blowing some serious black smoke out the back.
    i'd be looking at the pressure regulator or maybe a blocked return line (also causing excessive pressure) or a fuel leak worste case scenario.
    i drove a VN V6 home on 5ltrs (5km's), it idled for another 10 mins, did a long burnout,new tyre to zero tread (on private driveway......mine:D ) then idled it to let it cool down and it still didn't run out of fuel.
  5. Bz Kn33z
    Bz Kn33z Active Member
    Mildura
    Black VN V6 Turbo
    My VN V6 drinks the fuel to, fuel pump is aftermarket to, but when i was under to car looking around the other day i seen that 1 of the lines has a crimp in it prob only letting thro 60% so i will chase it back and see what it is,prob get like 14-15L or something like that to 100klm but yeah also might be my driving i dunno lol
  6. VTPREDATOR
    Warwick
    VE SS SPORTSWAGON
    yeh its only idling. (no tailshaft or exhaust yet, left manifold not bolted on yet). i can smell petrol from like 40m away from the car. dont see any leaks. will check the return line and fuel lines under car.
    can i install a aftermarket regulator and leave the old one where it is?
  7. immortality
    Sth Auck, NZ
    smells like a fuel leak to me. check around the injectors, a faulty 'o' ring could do it.
    if your going to run a aftermarket regulator you would want to get rid of the factory one
