funny noise from front
prjacksonau
64
vn ss
hey hope sumbody can help a funny noise started comeing from the front of my vr v6 a few weeks ago when idleing seemed 2 be comeing from power steering pump changed that an still ther so 2day i changed the water pump an yes its still ther it is def 1 of the pullys as when u start the motor with fan belt off no noise an the harm ballancer looks ok just wondering if any1 got any ideas as this is sending me broke changing good parts even tried putting the pully back on pump with put the shim but no go please help
calais_cruzin
Calais_Rattling....
Gold Coast
92 VP Calais 3.8
Take off the belt n spin ya pulleys for alterantor, power steer pump an yadda yadda... Til ya find the one thats makin the racket
I got me bet on Alternator bearings.... Does ya batt light com on ever
prjacksonau
64
vn ss
done that allready an no noise an my batt light dont come on the alt is only about 18months old
calais_cruzin
Calais_Rattling....
Gold Coast
92 VP Calais 3.8
so uve started it without the belt n no noise so then i wouldnt be the harmonic, has to be one of the pulleys makein the noise....
Could be the clutch on the ac pulley but i doubt it.....
Do any of the pulleys have a bit of play??
Got me baffeld
ephect
Donating Member
VS Acclaim V6
most of the time, its the couple of idler pulleys and tensioner pulley.. with the car running, place a large flat head screwdriver on the bolt thru the pulleys and put ur ear to the end of the screwdriver.. if the bearings nackered u'll hear it.. non genuine pulleys are metal, whereas the genuine ones are plastic. hope this helps :)
prjacksonau
64
vn ss
hey tried the screwdriver trick but couldnt pick anything i have a felling that it is the tension pully dont no why i also had that feelling with power sterrting pump then water pump any1 got anyidea how 2 test the tension pully
prjacksonau
64
vn ss
ok how do u change the tension pully do u just change the pully or the whole gizzmo an if its just the pully how do u get the bloody thin off
ephect
Donating Member
VS Acclaim V6
Nar u dont have to take the whole arm off, u can replace the pulley itself, but the bolt thru the tensioner arm is a LEFT HAND THREAD!!! =) (yes have stripped one myself in the earlier days) u should be able to pick one up from repco, bout $30..
Good luck :thumbsup:
prjacksonau
64
vn ss
ah thats why bloody thing wont cum off turning it wrong way thanks
