Fuse and relay layout dilema.
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
It's not the copy I did for you is it?
Seem to remember posting a copy to someone on here.
Edit: Could have been Immortality. Not sure now.
No, it wasn't me.
Brett Thompson
54
Hobart
VZ Ute
I've been googling this nearly the whole day and only just now found what I need.View attachment 199971
Just for comparison here is the VT oneView attachment 199972
Once again the Holden Service CD is wrong.
Got no brake lights in my VU and the label inside mine (same as above but hard to read so thanks) doesn’t identify brake or tail lamps. Tail lights and indicators work but no brake. Any ideas folks?
accentstencil
71
The brake switch on the brake pedal would be a likely candidate. Very awkward to replace though.
lout
60
Langwarrin Victoria
brett you need the fuse panel under steering column
hinges are at bottom of panel
grab top of panel under steering column and pull towards you
BlackVXGTS
Melbourne, SE
Thanks lout, that's good to know. Perhaps I shouldn't place too much credence on what the Holden service CD says. It's caused me concern a couple of times now.
The CD is a bit difficult to find things, you just need to know where to look. In this case it's in the VXII sections (excerpt attached below). Having said that, the CD is far, far better than the service manual documentation GM puts out for the VF series.
  • VX, VU, WH Series II Fuses etc..pdf
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
As lout said.....fuse panel under the steering column.
Brake light fuse should be F5.
Brett Thompson
54
Hobart
VZ Ute
Fuse panel took some finding, old mate before me had broken the hinge and inserted a screw.
Anyway fuse all good and at least have brake light on passenger side but not drivers. Was hopeful for some reason that a left and right rear fuse may exist.
Looks like time to pay a sparky to check. Is a pain in the rear to get to tail light as it has the poly tub liner installed. That has to come out first but is fixed in fairly well
Any ideas what the female plug is under the fuse panel and above the brake pedal?
Cheers folks
Immortality
Staff member
Sth Auck, NZ
Checked for corrosion inside the fitting?
You can get cheap multimeters at jaycar or your local automotive outlet. Easy to test if there is voltage/continuity at the fitting.
