This may also be the dreaded Hazard flasher switch playing up. Try pushing it in and out rapidly about 5 or 6 times and you might find your indicators mysteriously return to functioning.
I wish it was that easy i did as u quote but had no luck. Im thinking maybe the fuses need to be replaced coz the wipers are also not working can u please tell me where i could locate the fuse box as there is nothing under the dash drivers side or passengersThis may also be the dreaded Hazard flasher switch playing up. Try pushing it in and out rapidly about 5 or 6 times and you might find your indicators mysteriously return to functioning.
Thanku it was the fuseWe told you there is a drop down panel under the steering wheel. You use your key to turn the clips 90deg and they pop off. The panel then drops down. The fuses are near the kick panel.
