Fuse no 14
51
2000 l67 commodore berlina
Hi is fuse no 14 instrument panel fuse box also got something 2 do with the pcm aswell as the cigarette lighter fuse that it is listed as. Cause my workshop manuel says fuse 14 is 4 the pcm.anyone know.vehicle vx commodore.
lout
Langwarrin Victoria
VX Executive S2
series i fuse 14 ECU, BCM
series ii fuse 14 cig lighter
most of the workshop manuals use vt diagram for vt-vz
51
Thnxs 4 the heads up m8 .i know the bcm fuse on mine is no 31 fuse would that b the same as the pcm or is the bcm something different?
lout
Langwarrin Victoria
VX Executive S2
bcm is body control module, think door locks, power windows, indicators, wipers etc
pcm is power train control module, aka ecu, controls engine and auto transmission
series i fuse 31 is also for bcm and ecu,
series ii fuse 31 left hand headlight
51
So lout any clue what fuse is for the pcm now ive got a series 2 v6 but fuse 31 is 4 the bcm on mine. Y im actually asking is i need to pull pcm fuse & fuse 35 (ign) on initial start up 2 build oil pressure its on the important side of things bro.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
If you pull the bcm fuse it won't crank over .what engine is it
lout
Langwarrin Victoria
VX Executive S2
just pull the fuel pump relay under the bonnet
