Gas Problem
VL Berlina 5speed
Apprentice Panel Pusher
Project VL Show car, VS Exec, VY Ute, YZ250F
my old man is having a problem with his vs on gas, it is a factory fitted system and has been running fine for many years until now,
the problem he is having is that when he flattens it or puts the motor under tourqe it blows the top off the air box off. it also blows the top off when going up hills with the air con running,
what is causing this? i did a quick search but could not find any info on causes,
my guess is a leak in the intake pipe after the injector causing it to suck air in and dump the gas in the box, then pop. is that right?
cheers
sean
WAGON MAN
Gas Sleeper
North Coast , NSW
VX S2 Berlina Wagon with Phreddied bits.
How long ago was the gas system serviced ( time / kms)?
VL Berlina 5speed
a while ago i am told, proberly few years
and ks for the car is at the 331243 but it has been wound back from 385 mark(dad sold the car to a *unnamed* holden dealer and they sold it to a yard then i found it 4 sale, clock wound back so told him and he got it off them for dirt cheap) but motor is secand hand vx motor and trans
we had the injector taken appart recently because it stoped working and kept stoping the car from sucking any air in, i replaced the gasket seal around the shrowd as it was sucking in air, interanls looked clean and undamaged, was fine after that now its poping the top
WAGON MAN
Gas Sleeper
North Coast , NSW
It sounds like the Gas system needs a good tune.
Take it to your Gas specialist for a tune up asap (they recommend 12months / 20,000kms).
You will find the gas mixtures will be way out and the reason for it backfiring while its under load.
If you haven't changed the spark plugs for a while i would replace them to.
padrickz88
Rick =]
sunshine, melbourne
www.facebook.com
VN V6, nothing special
mine used to backfire to.... except mine is a vn and alot older.... but usually when that happens i just replace the sparkplugs and no more popping off the box:D... but a tune on the gas cant hurt:D
bennzy
Victoria, Melbourne
2001 VX II Berlina GenIII V8 5.7
when ever you change the spark plugs its a very good idea to get a tune done, stainless steel leads are apparently the best ones to use with the gas system ive been told
deserthead
Cairns QLD
VS III l67 Column Shift Ute
Yep wayyyyy over due for a service, and make sure he runs it on petrol at least once a month as a minimum otherwise the fuel pump, line, and injectors will gum up again . . . .
VL Berlina 5speed
yep the car is ran on pulp every thursday to work and back 60ks or so, and also mortan lubercation drip system is used to keep it lubed up
ok well we have the idea a service is need now the question is does anyone know any decent gas spezailst in adelaide, prefferable south?
the place we use to go to closed down i think and he was top but now im unsure
deserthead
Cairns QLD
Nice, good idea with the lube system, I got flash lube installed when mine was converted, peace of mind for 100 bucks!!
Cant help ya with SA, Sydney on the other hand. . . . .
adams vn
vn s
i had the same problem with blowing it apart and spoke to a guy ata performance place and he suggested getting a k&n pod filter in its place and get the system tuned seemed to work for me!!
