Hey does anyone know if a level 3 gauge cluster will fit a Series1 VY S and if everything will work correctly? :bang:
yes it will but it will need to be programmed to suit your car, the only thing to watch is make sure you have the same series as some have a different fuel guage setup & will work backwards. this can be corrected with some custom programming but it can be costly (about $180) Rob
Thanks Dr Bob Thanks for letting me know mate. Much apprieciated. I will be able to go on ebay now and buy with confidence.:thumbsup:
it was moved to the vy section, was originally done in the v6 section. dont worry everyone does that every once in a while
Be Careful! I hope you paid attention to what Dr Rob said. Be very, very careful that you get the correct cluster for your model. Make sure that it is a VY Series 1 cluster, not a Series 2. It will save a lot of hassles down the track.
I put a caprice instrumentation in mine, just make sure it has a grey plug on the back. everything can be programmed by your holden. If the milage is over 100,000k's, places like namiis(www.namiis.com.au) can reprogramme the mileage for about $130.
