gauge wiring ground battery?
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
1995 VS Commodore v6 ecotec
hey all, I was wondering could I wire the earth wire from my gauges directly to the negative terminal on the battery?
would it work?
would it drain the bat when not in use?
Would it be an isolated enough ground point?
or is it better to just put the ground point somewhere else? If so were?
Ive spent months trying to get all this sorted, hopefully you guys can help, im goin gray I swear hahaha
cheers guys
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
The best ground point is the battery, but if you have good earth points from the battery to the body and to the engine, then anywhere metal on the car will work. The reason the ground points are on the body is so you don't have 25 000 earth wires going back to the battery. What I have done in the past is use a heavy gauge earth from the battery to somewhere in the engine bay and run all the earths to that.
paulsautoelec
54
darwin
vr ute
what sender are you using for your gauge is it a sender or switch
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
also i should ad that it and the gauge are brand new, i put them in last night, to replace the previous oil temp gauge and sender that was doing the same thing
Immortality
Staff member
Sth Auck, NZ
mate, try cleaning up all the connections first. the factory chassis earth is fairly poor after 15 years. clean battery terminals first. make sure there isn't any of that corrosion stuff happening on the terminals. sand the inside of the terminals too.
remove all the wires from the chassis earth and make sure there isn't any paint under it. clean around the stud (remove paint if necessary). clean all the cable connectors and refit.
do you have a sound system installed?
if so, fit a bigger cable from battery to chasis connection. at least 8G but prefer 4G cable
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
will do mate!! ive just got back from repco, ive bought some wire (god knows what size it is) for general wiring, ive also bought a pre wired 4gauge ground wire, a gold termanal thingy (clamp) and some gold loops to re wire the other neg line (the one that goes to the car not the chasis) and will be getting to it soon, while im at ill give the posotive terminal a good clean to, hopfully this will sort it, ill post pics after especialy if it works!!
